Anyone removed their rear seat, etc and re-registered their car as a 2 seater?
Edit: I know Richo did but I don't think he comes on here anymore.
You'll have to remove your seat belts as well and fill all the holes left by the removal of the belts and seats (this doesn't mean put the bolt back in it means fill them so they can be used again) and then you have to produce your car to regency for an inspection.
i bought some aluminium sheeting today and got creative.. still have to take it all off smooth edges and bends and give it a good clean... tonights task is aluminium brake ducts.. super sized :P
your a DIY genious Sir Jenksalot. make me one :P
hahah at this stage the aluminium is too thin for it to look pro... small dents and such.. if i find a thincker aluminium sheet id think about making them properly for people
Jenkies, where'd you get your pod filter cover from?!
just jap on the forums
anyone know wat injector latency i need to imput on my pfc for nismo 550cc injectors?
its for a rb25det..
cheers
p.s. wanna make me one too jenkies? ill pay u for it :laugh:
u could just make a copy of mine.. but as i said b4 the aluminium im using now is too thin... hows it all running ?? or i take it its not if ur mucking around with pfc? cant wait to see it
RIP ... Wendy Van Gasteren
http://www.news.com.au/adelaidenow/story/0...008-910,00.html
Killed 2 years ago today at O'Halloran Hill by motorcycle colliding with a pedestrian and then traffic behind not seeing her.
Was one of the best friends, neighbour, riding buddy you could ask for.
A tragic loss to the motorcycling community in Adelaide, who co-coordinated with me a few awareness programs. Not forgotten.
Ride safe, drive safe.
yeah very sad, I still remember the day it happened
lol, I'm coming over
Mark where's the best place to get a sheet from and how much?
need some help with something
i dont like my black intake plenum with paint chips , and i want to make it silver .
i can get it acid dipped cheap as my mate's dad owns a company that does all that stuff .
are there any precautions i need to take to ensure that it will still work/fit after being dipped ?
its 0.5 mm sheeting 900x900 from recollection $28 a sheet from stratco.... i wanna find 1 mm or 1.5 mm sheets of aliminium... the 0.5 is too thin, dents and looks a bit cheap and nasty but it still does the job.. sealing all my airbox with it atm.
http://www.samsung.com/au/consumer/detail/...cd=YP-S3JQB/XSA
Full Multimedia Device with Video, Music, FM Radio & FM Record, Photo & Text Viewer, Alarm, Clock, Games.
- 1.8” TFT LCD Screen (QCIF 176 x 220).
- DNSe2.0™ (Digital Natural Sound engine) Technology.
- Long Battery Life: 25 hours audio, 4 hours video playback.
- Light emitting touch pad controls.
- Supports MP3, WMA, MPEG4 (SVI), OGG, JPEG, TXT File Formats
Thats the link, if it works..
Its a 2GB version in white.
As for what id want for it, i dunno lol.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
