hahaha damo im sure donnan will work some good power.. get him to fiddle with the ex cam gear also....
krishy.... injectors were a headf**k... ill tell u wat to do but u can do them.. my hands are cut and grazed up like no tomorrow......
Look what I picked up off eBay and just arrived :P its nice! 1/38 scale/120mm long + its RWD lol need to grab some batteries for it
lol sweet are you going to do some hoon driving with it down rosewater terrace ill pop out off my house to see it cruising past me lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
