LEAK???? oh dont say that!!! oh well donnan will check them for me :P
No offence, but donnon doesn't wanna have to deal with shit like that....he wants to tune the car and get it out. He's probably all booked up anyway. So best to make his life easier and check all that shit beforehand.
im tempted to go wash my car in bare feet , shorts and a tshirt
after sanding back a car and pulling a rad support off another , im quite fkd and need to cool off
temping to crack a green apple udl or two but i might wanna go out later :)
damn p plates
Yuck. Get some real alcohol :down:
shouldnt you be bricking your phone
oh wait... :(
:D:D:D:D
haha, I know the feeling. I should hopefully be off my P's in a couple of months so I'm a bit of a granny driver at the moment. :)
i dont even know what i have to do to get off my P1's , ive lost 3/4 demerit points , anyone know when i can get P2's ?
temping to crack a green apple udl or two but i might wanna go out later :down:
LOL I used to absolutely LOVE the Green Apple dels. It's like getting hammered off apple juice (both of which I am a fan of :))
Don't really like the cheap shit these days (Red Bear, UDL etc) as it seems to give me nastier hangovers than it used to. Smirnoff Double Black is the weapon of choice now, or TEDs if it's hot as fk or with a meal.
On very very rare occaision I'll get into the Bacardi 151 with OJ mix. The Vitamin C in the OJ means no hangovers, but the 151 means 'royally slaughtered' would be an understatement :(
hahahah ditto
I swear that stuff has something weird in it that makes you do the stupidest shit - I mean moreso than other alcohol :)
I sometimes turn a bit sour when smashed on that shit though, hence the very rare occurance of me consuming it.
Also, I had Canadian Club for the first time the other day (NOT usually a drinker of those sorts of alcohol) and it was bloody nice. Might have to have a night on it and see how I go
Edited by AndrewJZX100
LOL I used to absolutely LOVE the Green Apple dels. It's like getting hammered off apple juice (both of which I am a fan of :) )
Problem with the cheap stuff is it wrecks your guts too. Always felt like crap the day after drinking Old Crow or Woodstock (yech)...
Now I don't stoop below the wild the sphincter of the universe.... Makers mark is damn nice too :down:
-D
Yeah I'm off it for that same reason Dohmar.
Had some interesting nights on the goat lovers :) Like I mentioned above, not into bourbon/whiskey, but the CC went down bloody beautifly.
Might go with Double Blacks for the dance, TEDs for the eats, CC for the chillout.
151 is the strongest legal alcohol u can puchase, being ~76% and a full bottle being 44 standard drinks lol. i dont drink but i see the affects of it all the time.
Edited by steveP
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
