Plug in 66% as you had previously or slightly less. Might be worth going a little leaner with 60%.
When cranking go full throttle.
It probably won't start because the plugs are wet fouled then its just a big vicious circle. :S
i tried that the other day to no avail.
Adrian, we need to pull the plugs out,start again..I'll get it going after the job interview.
Edited by Ryanrb25
well.........
the car seems to be running on 4cyl with the new injectors in.. so out the injectors come and off for a flow test... hope two arent f**ked...
oh well we will wait and c how it goes... its all a learning curve!
Checked the injectors are receiving power with a multimeter?
The injectors always receive volts so simply turn the ignition to the on position and check with a multimeter.
The ecu earths the injectors to trigger them so obviously shove the neg of the multimeter on the chassis/battery.
Runs on 4.. Are you sure the plugs just arn't fouled.. Thats what a mate of mines did for a while we warmed it up, raised rev's and she cleared up. :huh:
Not in the mood.. Go and have a bat. lol.
Run it for a good 5mins or so with rev's slightly up.
Make sure the injector correct is set right so go with 'slightly' lean at 65%
.... It could be running for the weekend ...
Another way to check the injectors are firing and when they 'should' be firing is to pull the cas out; ignition to the on position and then spin the cas clockwise slowly when looking at the shaft from behind. You'll hear the injectors click click click. Make sure they follow the firing order. :unsure:
[Vent]
Put turbos back on, sell car?
Pay for removal/reinstallation and just take it in the nuts?
Sell engine, buy R34N1 engine + turbos and apply for an engine conversion?
In SA, that actually seems like a good idea....ARGHHH.
[/vent]
yeh ive done that before but not with the new injectors.. ill give that a crack later..
if there not firing wats the go? there rooted?
[Vent]
[/vent]
how much for the n1's? my car needs a chrissy present
If there not firing its multimeter time to see if the problem is with the loom or the injector.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
