C.mon you really need SAU to answer that question
Just wondered if anyone would pop up saying "yep i got mine from xxxxxxxxx and they are awesome". At least i didnt start a thread about it.
Isn't Adrian working today? God, whats not going wrong with his car at the moment. It's like one thing after another
Yeh hes working, yeh im giving him a hand pull his injectors out tonight, hopefully with them cleaned and flow tested they come up ok, then its just a tune and hes set.
jarrad u buy my rims and ill buy ryans rims :)
Well who wants my TE37's?
i know the guy selling the xd9 pair... and there is another pair on ns.com selling atm.. a pair in white and a pair in bronze!
That'd look so drift spec haha
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
