Bloody hell I just woke up in the most painful way ever... for some reason I seem to have woke up as my body leaned forward then BACK DOWN WITH MY HEAD INTO THE f**kING CORNER OF THE BEDSIDE TABLE.... f**k.... yeah laid back down clutching my head in pain... smelled blood f**k turn on light theres blood on my hand. Great. Wash it off, grab some tissues, some ice and a couple panadols....... far out I can feel a descent bruise there already...
Well atleast it got me up to turn the computer off as the downloads has finish. Got a few hours of sleep til I need to be up... and I'll just sit here a little bit longer until the pain subsides.
Vu you fail at waking up :)
Clean? Are you serious!? It was last washed properly for the Stag cruise, lol. Ryan works night shift and there's no undercover parking so it was out in all that rain we had the Monday night.. I guess that was enough to clean it off a bit. I have noticed it needs a detail because you can see swirl patterns all over it when the car's in the sun.
Sez
ps: thanks for complement Damo :)
Edited by Ryan&Sez
Sez
must be coz its black, you see a flash of it and it looks clean :)
Should try that at the next picnic event! :D:)
18x8.5 +30 and 18x9.5 +30. Rears sit perfect, fronts could use a spacer to fill the guards better.
sizes on that S15 i think were 9.5F and 10 or 10.5R
Edited by muirsky
http://speedhunters.com/archive/2008/07/02...inimal-s15.aspx
The exterior enhancement consist of Spec-R side skirts and rear spats, that's basically it. Of course the other most noticeable change on the outside are the massive Work Meister 3 piece wheels in 18x9 in front and 18x10 in the rear, et is +4 all around.
How's that for a wheel fitment Antonio?
The suspension setup has been set to 5 degrees of negative camber all around. To do this Terry used Cusco and Tein Control Arms, Fortune Camber Plates and Fortune 40 way adjustable coilovers with 50mm pistons. The standard brakes have been upgraded with Project Mu brake pads and stainless lines.
Lol, 5 degrees of camber.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
