now im sure ur all realising on my days off i get creative usually posting a pic of something ive creatid for my car... this time round i bought a logitek g35 wheel and made a frame for grand turismo prologue..... with the 6 speed gated shifter its awesome!! just gotta figure out how to get the clutch working
Sick, so ill be round on Sunday to test it out :D
Picked up some audio today while Car toys have there sale on.
Got 2 12" subs roughly 400-450 rms each subs
Mono Amp which will power them plus more if needed
A port for the sub box that i need to make
and Terminals for the box :
should produce roughly 130-140db :D
dls nobelium? nice way to to drop a few grand. :P:)
ah, awesome. should be nice and loud, wish i had the cash to pick up some sound gear, stock speakers are garbage and my head unit has seen better days.
I got a Pioneer Carrozeria double din cd player with fm expander than can be yours for $60 until you get a decent unit?
Get the RDA slotted rotors Dave
have been so f**king happy with them since i got them in
so much better then standard....but then again my rotors were stuffed
http://www.skylinesaustralia.com/forums/Rd...Gr-t200718.html
message the guy and ask him if he can get it for your car
very helpful dude
Edited by Krishy
