dave, whats up mate?
my family's retarded. had my dad threatening to leave for no good (or real even) reason last night, with my sister blaming me for all the arguments that happen in the house, and the rest of my family's in perth, so yeah, not an enjoyable xmas really.
seems not all jolly tonight pulled up at the lights next to a commo and sitting waiting for the green window drops and begins comments of pretty slick im like yeah thanks, then its followed by you get that from japan im like ah, then begins crazy bogan attack of abuse with two mofo's jumping in each others laps to yell out the window that wasnt completely down. so much crap was getting yelled they were inturupting each other with it. gave them the :)
lil stunned by rude attitude on xmas but hey what else you expect from bogans :devil: note: i had the xmas hat on
but anyways merry xmas all hope ya had a good day
Edited by Inline 6
finished setting up my coil overs this week! tightened the shocker stroke and gave it a bit more progressive spring rate and amped up the damper! handles really good during mid corner but the entry isn't as flat as i'll like it to be, it's a bit neutral and it's predictable with a bit of comfort on the road and now on some drive ways one of the wheels pops of the ground because of the short stroke :) . i reccomend trust coil overs to anyone who likes a bit of comfort
Edited by nos man
Cars suck ass if its not one thing wrong its another!!!!!!!!! clutch fan gone for the 4th time in 6 months and now getting engine light flashing on and off
i have clutch fan for sale
u want it dude?
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
