is there a toyota chaser forum???
http://jzx100.com/
hey chad, with the hid's, add this bloke to msn; [email protected], hes known as 'angry' on the r31 forums, has sold about 90 hid kits there, good bloke to deal with, knows his shit pretty well.
jzx100.com
also, this place clearly needs a mod who drives an s14.
and i was beaten to it :(
bingo
ive got them, orgzmc has them in his drifter, and madaz bought a set earlier in the year good bloke to deal with definitely
yes great kit, and i got auto perfection to install mine
EDIT
after a little looking it seems another fine forum (im guessing its fine) comes from SA
the registrant of JZX100.com is
Registrant:
Random Seed Design
50 Tarqui Dr
Paralowie, South Australia 5108
Australia
You're gain, Luke! There's a huuuge RBT/defect blitz on tonight!!
Yeah we saw one rbt just out of the city. Thought it would be the last drive before i go to qld on friday.
And Dave was a last minute thing, was just a quick eagles, greenhill, lofty run.
Wow... I just realised Cubes has 'retired' from SAU's moderator team and now Heslo's a mod here...
cubes bought a whole 3rd dimension to the sa sau section now where stuck with this 1 dimensional sled character jeez
a picture to demonstrate :( these dimensions for the ill informed
post-31501-1230692129_thumb.png[
and finished cubes
i take it he didnt have much time for it as he was hardly posting on here as of late.
a new reign of terror shall now commence
this post almost became educational
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
