rofl,
Poll Results
Thanks for voting, here are the results so far:
Have the tougher laws introduced in 2005 reduced hoon driving in SA?
Yes
29% (43 votes)
No
70% (105 votes)
Total votes
Total of 148 votes
This is taken from the poll on hoon driving..
Pathetic creatures who "need to" do burnouts and all that childish idotic behaviour. Who says they "need to" do this? How about getting a life, some real responsible friends and a good hobby? Look at other countries. Does Europe have this problem? Not really. Let's ask them why. There is plenty of opportunities here to let off steam, like football, etc. etc. "Test their vehicles"? What for? Read the instructions: a car is a means of transport, that's all. Not a goofy toy to show off your infieriority complex and other mental disturbances to people who aren't really interested!!!
Seriously some people have no idea. Yet they feel the need to voice an opion about a subject they clearly do not understand or know anything about. F__k they make me angry.. I bet you the same person who wrote that comment is also the same type of person who drives in the right hand lane and sits 15km's under the speed limit then glare at you when you over take them even though your still going under the speed limit.
End rant.
F*ck me. I've just been trawling the Japan Yahoo car auctions, and I found 3 32 GTR's which were MINT! One was going for 24k AUD and had 21,000k ORIGINAL k's on the clock. It's been garaged for years! Only 1 owner with books to prove the k's!
And another one, had books to prove the dash board change over to prove it had 34,xxx k's on it.
So many people rant on about the k's being wound back, but there's plenty of Skylines who have little k's yet are original k's with books to prove it.
Most car ads also display the person doing a comp. test on the car, with pictures of each reading and they even show you the condition of the spark plug. Now that's what I call a decent car ad!!
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
