Good ol' Koshi got on the hoon bagging band-wagon this morning at 7:10am... showing more NSW/Vic footage of VN's spinning the wheels, etc. Then started talking to a random cop about it. Then they showed a story of some P plater kid who had his VR impounded 4 times for hoon driving.
Then, I flicked it over to Channel 9 and they were running a interview with Angry Anderson about hoon driving and his thoughts on it, and then they showed interstate footage of burnouts, etc.
The media can't get enough of the hoon bashing shit!! There's a f**king war in the Gaza strip, and all they care about is speaking to VR-owning P platers about burnouts!
/endrant
For the record, I hate Koshi and Mel. They're too happy for that time of the morning and it pisses me off!
at least they are showing footage of commonwhores.............when ya think about it a majority of all the p platers out there that drive a commonwhore are hoons in it.
its probably a good thing they are showing those cars and not targeting on the imports with the footage.??
oh well, wont change, everyone might as well get over it.
True that damo, nothin will change it no matter how right or wrong we are etc.... they aint gonna change the way the commy/ford drivers drive. lol! and wont change the opinion of the law and other people etc. :laugh:
God damn. I just finished putting the HICAS back on - damn thing finally decides to go in... now that THATS done the rest of the stuff needs doing is fairly minor...
Would my chance of passing regency first time increase if I get a hot female friend to take it through for me due to me "having to work late"? :P
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
