That's a pretty good result, Mitch.
Considering stock standard RB26's will pull between 170kw and 180kw at the rears with the 4WD fuse taken out (R32's) on stock boost (meaning the restrictor still in).
Mine pulled 174.6kw at the rears on stock boost (the GTR still has the stock boost restriction in it! Never been touched), stock turbos, 3 leaking injectors (found that when it was on the dyno), a collapsed centre muffler baffle and a stuffed cat. No ecu mods, no EBC, stock intercooler... only mods are twin Blitz pods. Pretty good result! And the engine is in good condition (170psi across all 6 on a compression test, leak down test proved it's healthy, too).
Once I've replaced the exhaust with a full new system, I'll put it back on the dyno and see what I get. The injectors have already been fixed. My exhaust is that badly clogged, that I can expect to see a large difference (like, 20kw or 30kw extra lol).
Mitch, What do you mean you've modified the coilpacks? If you've ripped out the stock coils and put in Splitfires thinking it'll improve performance... you've wasted your money. Nissan Standard Coilpacks are the best you can buy... Splitfires are a cheaper alternative.
Edited by CRoNic...
yeah it doesnt really explain itself all that much. you have to determine if the argument is logical. a hint.
All ducks quack
donald is a duck
therefore donald quacks. It states that ALL ducks quack, and Donald is a duck, so it as a valid argument.
I agree steve my mates GT went from 224 at Aussies to 257 at KPM with the addition of underdrive pulleys only :D (which in reality would be 5-10rwkw at the most). Hows your car doing mate got it sorted?
had my car dyno'd at MRE, then 2 months later no more mods done got a reading at KPM that was 20rwkw higher :s
yeah im not saying its a performance mod, its the only thing thats been changed on the motor its self :P
Dyno readout's differ due to different shoot out modes used the amount of brake that is used to simulate road conditions
damo will post my thoughts later when im home about that logics test
Nozila - where did you get defected
mitch, a cop pulled you over and issues that?
yep , pathetic if you ask me but hey, he was nice and liked my car and wasnt out to defect me , just sucks being unemployed at present and having to pay this fine and get new tyres , but oh well
least i can still drive
Yeah i was thinking of taking mine there to see if i could squeeze 300 out of her :P
What exactly was the fine for?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
