Yeah I hate lag too. 350kw is bloody heaps for what I use the car for (daily) and would def get cam gears and cams.
Just depends on if I can find 34 N1's cheaper than the brand new garretts - and even then it might just be worth paying the difference to have brand new turbos... so I'm guessing -5's are what I should start saving for...
-D
Yeah I run 280kws and thats plenty for me on the road and track :P If I got the N1's could run more boost :P and get more of a rush :)
The 2nd hand R34 N1s do come up on teh forum often for around $2k...Just need someone that knows turbos to go with you to check there condition see if the wheels spin freely and no noise and see if they have shaft play :P
CRD where selling the 2530's -5 for an awesome price a little while ago...check them out here on SAU. So was another trader that Luke (heslo) was going to buy through, Wonder if he ever got his turbos??
Had a quick look at RB26 results: try this
18psi with high flowed steel wheels = 280 odd kws
18psi with -5s = 316kws .........
Only had a quick look - maybe there are others making more power on high flow steel wheels?? Post em up if you find them.....
hmmm, the reason i ask is the whole "defect" thing, and i could get my car thru regency with steel wheeled/hi flowed and not worry about having to take em off, put stock on, then do it all again once i pass as im under the impression regency only check the numbers on the side of the turbo?
hey Ben (Dohmar)
any chance you know the name of the dark grey sharks in this clip?
http://www.youtube.com/watch?v=eiM4YjTGI2I
Black one with red tail is called (funny enough) a red tailed black shark (Labeo Bicolor) (and they're bullies in the aquarium too). Theyre not really a shark, as theyre a member of the carp family.
The silver ones are called Emperor ID Sharks in the prelude to the clip, however thats just another name for Shark Catfish (yes, its a catfish). They look rather cool tho.
-D
ahhh cheers,
just doing some re-search as to what can live with what...
im thinkin of turning my 70 ltr into a tropical set up to get some practice before i move up
to the 300 ltr after my holiday.
Hey guys, got a bit of a pickle here as I didn't realize Ryan isn't working on people's cars and I was ment to get mine wired today (sorry to hear you got stuffed around bud, cheers for the help you did provide) so I really need to get my car wired up ASAP (loan car for work is now gone). Anyone got any experience in wiring up a series 1 RB25 to an R32? After help asap and am willing to pay cash and beers. Basically motor is all in ready to wire but I'm at a bit of a loss where to start. Gonna start reading what I can right now.
Give us a hoy if you can help and would like to earn some coin, will forever be in your debt.
250 is good power man, settle for that...it will stay very reliable too.
yeh i have to say 250 is a good power range... stoked as with 250 and responce...
cant find traction thou lol...
Yep they check the housing number on the side of the turbo. I don't know if there's any way for them to check if the turbo has been high-flowed, as there's no exterior differences? It's all internal?
Would -7's give similar power to stock or closer to the -5 ? -5 = quicker spoolup, is that correct?
Cheers
-D
Im pretty sure the -7 are the smaller ones, then -5 and -10 are even bigger. The numbers do not go in order of size for some strange reason.
My -5's come on full boost at 18psi at about 4500-5000rpm
Check out this thread
GT2860r-7 or -5 Responce
Here they all are; The reason the don't go in order is because the -X comes from the last number in the CHRA code and doesn't mean anything. The thing is with the -10's from the picture on the Garrett website the factory piping won't bolt up to the compressor outlet as they seem to have the S-Series 3 bolt flange not the GTR's 2 bolt flange. unless they have just showed a general picture of the GT2871R and it actually come with the GTR housing.
HP quoted is gross HP @ the flywheel;
GT2860R-7 310hp each
http://www.turbobygarrett.com/turbobygarre...0R_707160_7.htm
GT2860R-5 360hp each
http://www.turbobygarrett.com/turbobygarre...0R_707160_5.htm
GT2871R 52T-10 460hp each
http://www.turbobygarrett.com/turbobygarre...R_707160_10.htm
Personally i think there is a better turbo than the -10 in terms of response. I have the same turbo as the -10 on my CA and it is reasonably laggy with full boost (17psi) coming at around 4000rpm, and that's with 1.8 litres "driving" the turbo. with two of these on a RB26 I can only imagine how laggy they would be with 1.3 litres "driving" each turbo.
The better option that I was talking about is the GT2871R 48 trim (the -10 is a 52T). This turbo is rated at 400hp but would be a lot more responsive than the -10, and are still rated at 800 gross FWHP. You will have to get GTR compressor housing fitted to it but it would be worth it.
GT2871R 48T 400hp
http://www.turbobygarrett.com/turbobygarre...1R_743347_1.htm
Edited by D_Stirls
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
