If anyone hears of a small fiberglass carf and a small elephant which look real can you please let me know. The business next door at my work got broken into and these two items are missing.
well, the 200 goes to morpowa tomorrow to have the clutch fitted (finally), and ill be picking up my apexi exhaust and maybe an intercooler aswell, yay. :)
my car is there atm getting my geabox rebuilt, Simon"s a top bloke he will look after ya!!!
And check out how many group buys have been closed, only a hand full left :)
http://www.skylinesaustralia.com/forums/Group-Buys-f61.html
Yep due to a few larger 'traders' going sour...
Glad they're finally clamping down on this and putting a start/end date to these group buys!
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
