anyone know of a bluebird or datsun club in aust?
there website?
http://ozdat.com/ozdatonline/
:rofl:
Been a member there for about 10 years now :D
Check out my supercharged SR20DE 200B wagon :(
Edited by RubyRS4
I know i get a bit shirty all the time about things but doesnt any one google any more gts lets just ask my online buddies and ill see what answers i get
i also understand its good to ask as i didn't know about ozdat but it seems people dont even look any more and just want to be spoon fed :(
boy its hot today
actually steve i did google and i found datsun club of south australia... but that wasnt much help.
and i few various other sites, so then i asked and found exactly wat i wanted..
did it kill u to read it in the wasteland??? would u like me to start a new thread?
thanks ruby..
yep, hot. Trains today are shit, little to no air con in the carriage i was on :(
public transport in general is shite in hot weather. and the govt wonders why people still drive to work. perhaps its because u dont wanna smell like the inside of a gym when u get to work (unless u work in a gym, apologies to personal trainers out there)
-D
boosting the stag yesterday, beaut tune from boost werx.
feels unreal, even with all that heatsoak the engine is so strong!
kudos to to the Slide turbo bush-bearing "stage-2" highflow, really really reliable & strong even with 46deg tarmac heat ..... nice
so happy with my stagea now. really is a nice drive :(
learned so much from this site, pity these days there arnt too many in-depth threads.
nah im quite happy with my current one! hooked on fishing and crabbing now tho :( haha
hehe im goin fishing weekend after next. hopefully get some snappers ... crabbing sounds interesting damo, are u using nets from the jetty or dab nets ?
-D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
