have a look in the radiator, if there the level in there is fine (down around 1-2cm) then just top it up with distilled water and the same with the over flow tank.
Yeah pretty sure the radiator is fairly full as I only checked the coolant a month or so ago and the overflow bottle still had something in it, just over the last few weeks it must have used the rest up.
So don't even top up the overflow with coolant, just use water?
I gave them a call there open till 4.00
I got a note on my font door saying that they try'd to deliver something to me today, i think it might of been my new Brake pads :D so i have to go pick it up after 2. i didn't know they delivered on Saturday's.
You can top it up with coolant if your 100% sure that you have the same brand and make of coolant that is already in the engine. If you mix active ingredients there is a chance that they can react and will turn to jelly, which isn't a good thing the have in your water jackets. Water is a safe option if your not sure since you are going to be changing it soon.
Thanks mate.
EDIT- If it just so happens to turn to jelly, what would I do about it? Just flush the radiator?
Edited by muirsky
i missed pendulum to see lupe, was still amazing but yeh prodigy was insane, like 15,000 people all going nuts when the bassline hit for smack my bitch up
+1 eye candy.
pendulum were good.
but I thought prodigy were kinda average to be honest.
They talked way too much shit instead of letting their good tunes do the work.
Some of the nice sounds and basslines were spoilt because of the stupid screaming etc they were doing.
good day out tho... :P
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
