Guest CleanAndSimple
Free Speech Rights & Australian Law
"Everyone shall have the right to freedom of expression; this right shall include freedom to seek, receive and impart information and ideas of all kinds, regardless of frontiers, either orally, in writing or in print, in the form of art, or through any other media of his choice."
hahaha thanks for warning me im not a mod geee so that means i dont have to follow the rules yeah?>
Steve has a point, as do ya'll...
a) One rule is for the users of this website - follow their rules or hit the highway
b) One rule is a federal law for speech in general.
When you sign up for SAU, you are asked to abide by the terms and conditions. These usually encompass rules which go above and beyond the law, or have a caveat that you are willingly becoming a member on the condition that you forfeit that right on this individual forum. So you're both right..
That said, the rule was to stop people trash talking a business when it isnt justified - sometimes this happens.
And on the flipside, if there was a shithouse business out there, I would not want to give them my business - which is where the rule comes in, as the mods of this forum dont want businesses to lose customers on the basis of a single report (which could be biased and unverified). Ultimately the mods have discretion, and its a grey area at best.
I think a bit of flexibility is required. For example, I posted a very vague reference to a dodgy auto electrician near my house and never got cautioned or pmmed about it. I think its more a safety clause incase a business threatens SAU with libel suit. Andrew and Pete could possibly add more to this, but tbh it comes down to commonsense. You can post your experiences publicly without naming names, and if people are that concerned they can always PM you to ask you your personal (and more importantly, unpublished and uncensored) opinion.
-D
EDIT : Remember, if you defame someone in speech or audio its slander. In print it's Libel and attracts a more severe legal penalty.
Edited by Dohmar
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
