Guest CleanAndSimple
i disagree if you setup up your ride height to a similar to factory height you wouldn't need and alignment if you say take an inch or 2 out you probably might
Right.... This is probably why i find that some jap cars have seized toe bolts, and are out by 21mm. (Treating them like commodores in my opinion)
Not to mention the fact its a 40 dollar, every 10,000km kinda thing. i spend more money on a cruize.
no skin of my back if he doesn't get a wheel alignment,
just i know that his toe would be out. and its good to check all the figures are even after installing coil-overs.
either way you don't NEED a wheel alignment, but your car does handle better, steer better, and wear tires better if you do.
Hence the fact i wheel align my car ever 5000km with oil change. (i would still do it even if i didn't work at bob Jane)
Edited by CleanAndSimple
all this talk of wheel alignments... i should probably get one done soon.
oh yeah, crickets boring as batshit. football interests me about as much as cancer does. and id rather stab myself with a diseased needle then sit through a game of tennis.
bring on the womens beach volleyball though...
Looking at all the cruise pictures, it's pretty low that cops had made such a huge presence on a cruise like that, considering what they're actually cruising for.
Sure, it's no excuse, and there's plenty of defectable cars... blah blah blah... but it's still bullshit.
I counted about 5 or 6 people getting defected... in the car park.
The end of the cricket was bloody awesome - apart from the fact that we lost.
Very exciting game though - never thought we would post such a low total either :huh:
Not liking the cricket is unAustralian and should be against the law. Fair enough test cricket can be a bit slow at times (that what all the beer drinking is for), but the one dayers are all action.
+1. I dont care how Pommie the game is, we have dominated it for decades, making it OUR game! Every team over the last 10 years at least have been waiting for this time, where Australia has to regrettably rebuild, and become a team again.
Decades? I guess you dont remember the 80s when the West Indies would rip the nads off the Australians repeatedly... and ya certainly can't claim it to be 'OUR' game when the indians are dominating the game from the admin level upwards...
Paint drying or cricket. At least with paint drying u get to kick back and admire the handiwork
-D
-D
so maybe years was the word i was after, not decades.
I still just dont see how a one dayer or 20-20 is boring to watch? Yesterdays game was boring, but a full on game like Aus v South Africa, aus posting the highest one day total ever, then south africa chasing it down. That was a damn exciting game to watch.
Dunno about 20/20, one dayers are >more< interesting to watch than test matches, but its still pretty bloody dull... and playing cricket in australian weather? 40+ ? Forgeddddit, you couldn't force me to be a spectator in those conditions, let alone a player... soccer, while boring as hell to watch (not least for the pansies that roll over clutching their legs and then taking a free kick without any visible physical discomfort) is actually pretty fun to play... afl, while its far far too athletic for a portly bloke like myself, can change at any given time and generally has more goals/points scored often than the single goal in soccer, or the occasional 6 hit in cricket.
Don't get me wrong. When the guys smash the ball and start running, it becomes interesting. But how many overs do u generally have to go thru before someone hits a screamer?
-D
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
