yeah i agree with your 2nd comment Roo it really isn't fair, agree with Pete too
Yeah. Wasn't setting out to insult religion ... as saying goes "words can't describe ...", prob best I didn't try to put to words. Tracy has gotten over it. One of the downsides to her occupation, having to deal with death. But in this case, the patients are children.
I know he needs to sell due to the split with his wife... its a fresh import with all the jap papers so I dont know why it is so cheap. He does all the importing/compliance himself too so no middle man charges and stuff.
What? When I split with my wife, she got none of my toys and I didn't sell a single one of them during the divorce. Lost the house tho :)
brb, ringing the bank about loan extension :)
DO IT!!!
Morning folks.
What a messy weekend I've got coming up!
Wakefield pub tonight
21st tomorrow night
Norwood food and wine festival Sunday
3 day bender, here we come!
As in the Wakey? Moon under water?....
When I posted it ages ago it wasnt actually advertised on any sites, he has only recently put it up :)
If I had the money id go have a look! I got my car for really cheap and there was nothing wrong with it...
I have seen this car for sale for well over 6 months at various prices - as low as $36k at one point. Given other R34GTRs are selling around the place for $50k+ there must be something seriously wrong with this one. I haven't driven it, but the fact that he won't let ANYONE drive it without a deposit also makes it an extremely difficult car to sell. I certainly wouldn't put a deposit down before I drove the car.
Ah well.
If it was Bayside Blue or Black I would already own it either way.
a minute's silence please :(
just waved goodbye to the R :)
Thats was a pretty quick sale Pete!! Its a nice car..Can I ask where she has gone?? Still in SA or interstate?
It's a sad moment, I did it with mine not that long ago :( But still have the race car! :)
I'm sure thats the one. I was there not long ago. Nice pub. :)
Watch out for the cop shop up the road tho :)
It was a hole before the renovations!
Thats where all the party people at my work begin there night haha... yeah Ill be there, we have happy hour in our meeting rooms tonight. 4 bucks for as many drinks and nibbles as you like! Woo Hoo!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
