fours n more dyno and automotive. They are in pooraka.
Stripped my 25det down before i brought it to make sure it was all good, did the conversion, added new bits, dynoed, tuned, have done the works to my car and the engine hasnt missed a beat in over a year of limiter bashing now lol.
82602011 is their number, brenton is who you want to speak to and tell him Luke with the R31 put you onto them.
ahk cheers , are they expensive ?
umm well they arent cheap, but would say competitive with boostworx pricing i reckon. You can be guranteed no corner cutting will be done and they are very thorough. He doesnt let a car leave his shop till he is confident it is 100%
ohk thats good then , ill give em a call tomorrow ! :D
cheers
KN6 K is on the plate, few listed for KN6 reckon mines the pearl one.
ah yours is Dark Grey and mine Gun Metalic Grey Paint Codes
can someone point me in the right direction of a workshop to get my engine rebuilt ?
i heard boostworx has a 3 month wait :D
and yes i have read the workshop list.
why not Tyrone from Import Compliance Systems or you got a quote and there dear
Mitch, also try Lewis Engines.
http://www.lewisengines.com.au/category9_1.htm
Boostworx are more expensive as they send off some of the parts to other shops to get done, where-as somewhere like Lewis Engines do everything in-house, so you have no middle man, hence the cheaper price.
see Toyo Tyres pulled all sponsorship from DA? New owners are "Ninety Degree Entertainment". They were going to only have one championship round for the 09 series at Oran Park unless a naming rights sponsor was signed. Phew!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
