OoOoOo!!
The trailer I seen for it had two cars speeding up to a truck hauling 4 petrol fuelages. The cars did 360's and latching there carsin reverse to the petrol tanker fuelages and then stole them from him and then the truck rolled over and blew up!!
OMG that is sooo realistic bro
WOO HOO. nearly got my 1996 hilux tray top 2.8 d should be good to go by tonight, on the way back i got pulled over by the police in the skyline.. was rather pleasant.. they gave me a formal warning for my p plate having fallen down and then i continued to have a chat with the other officer about the car.. we had a bit of a chat about sau and he proceeded to say something along the lines its good to see clubs doing something constructive rather than some of the "commodore" clubs around. asked about my semi slicks and things like that but generally a nice run in with the officers. + 1 to holden hill po po
some say imports are targeted by police, i suspect not.
awesome dude! Even if u did get defected, you would have just canceled rego and stripped it for dedicated track :)
lol its always good fun paying out the fast and furious series lol
btw damo you only have 4 teams in your dream team league or whatever footy thing u got going lol
Edited by Krishy
I know, not much interest! When it gets to the deadline they fill the league with randoms.
well then thats a bit f**ked up then
so common SAU footy fans get into it mate
i dont even follow footy and i am in there.....
you never know might learn a bit about another sport or soo
Main Street, Mawson Lakes. If you come up salisbury highway (from West) then turn right onto the bridge (opposite enffue), go over the bridge (which goes over the interchange), turn right at the lights, follow the road about 200m, its opposite Cafe Primo.
http://maps.google.com.au/maps?f=q&sou...x_HFDA&cd=1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
