Like the halfwits at Maccas near me constantly cocking my orders up :)
I've been wishing for a KFC up here for ages, but I'm thinking if the useless kids they hire at Maccas can't even 'cook' pre-processed meat patties and shit properly, they're gonna be up shit creek trying to get their head around the KFC jazz :(
On the plus side, there's some damn nice jailbait staffing MickDs at times :)
Edited by AndrewJZX100
Try going to the Macca's on Glen Osmond Road.
The manager there literally yells at the staff.
I quote:
Manager: "What are you doing?!"
Worker: "Making a cheesebu..."
Manager: "Who cares! Get onto the thickshakes!"
Manager: "Where's the big mac's?! WHERE IS THE BIG MAC's?! CUMMON GUYS"
Manager: "Oi, go and SERVE"
He's crazy.
LOL yeah I worked at the Bob Jane next door for a while, used to hit up that Maccas quite often :(
We used to get em to make us these fkoff custom burgers: A double quarter pounder with bacon, bbq sauce, grilled onion (or some different type of onion i forget exactly what) and a chicken breast in there as well :)
Would cost like 10 bucks a burger but goddam that shit was awesome :)
I quote:
He's crazy.
and he drives an N/A Auto supra that has a wicked 10kw worth of stickers
Yeah KFC in prospect has a habit of f**king every order up... i've gone there before and said 'I'd like 5 pieces of original recipe - drumsticks only' then they give me the box, I look inside and there are 4 wings....
Drive around to the window again and say 'I specifically asked for 5 drumsticks' and so they take it back'.... get a box given, look inside... 4 drumsticks.... and a crispy strip.
Bastards.
-D
Anyone have any recommendations as far as wheel nuts/lock nuts are concerned? I'm after something that'll give me a unique (to me only) key or socket.
Yeah i got some of those speedy wheel nuts that you need a key for all the wheel nuts
they are not too bad
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
