I spent this arvo getting the ute cleaned up ready to sell, chucked the old skylines seats in cos the Hilux seats looked like ass. Just need to do a bit of cutting and welding to the rear brackets to make them bolt up right :banana:
what kind of help?
btw, i cant find any info on this, anyone here an automatic genius?
basically my "power" button light for the automatic transmission flickers 16 times when i start the car up. doesn't happen all the time but it kept doing it last night, otherwise it shifts and drives fine??
Edited by tx3_90
what kind of help?
http://www.skylinesaustralia.com/forums/Rb...iew=getlastpost
anyone just see how a skyline driver got pulled off and ended up doing a runner and driving away and knocking over the police over? p plater in a black r33 series 2.
on Channel 7 news or something
Link?
Heaps of RBT's out tonight for the Adelaide Cup Day blitz.
Guest CleanAndSimple
yeah black gtst-t, r34 stockies on the front and standard rims on the back with a big kit, that the one? was on the news.
thats the one!, dont have a link becuase i saw it on the news.
look at what i found whist on ebay . :):banana:
http://cgi.ebay.com.au/Nissan-Skyline-R33-...A1%7C240%3A1318
Edited by CleanAndSimple
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
