i can too, involves the sale of the 34 however. just couldn't part with her if i tried.
id be able to keep the 14, and be mostly if not all debt free. its very tempting.
ill probably put a couple grand straight onto the loan, and just enjoy the rest.
and by enjoy i mean, new seat, coils, good rubber, dump pipe, front pipe, cooler, ebc, retune, and track day.
Edited by scandyflick
im confused mitch? wernt you saying that ur motor was dead and needed a basic rebuild?
no ,i never said it was dead , turns out the battery in the car didnt have enough power to turn the motor over .
started it up yesterday , was a loud noise , disconnected power steering pump and there was a small knocking noise in cylinder 6
car idles fine and revs up fine , just could do with some minor work .
i beg to differ how does a spun bearing now become just a slight knock in #6
As you might know , my rb26 has spun a bearing.
i have replacement parts to fix it but my only problem is getting the engine out of the car and doing it myself.
seeing as im really low on cash i was wondering if anyone could lend a helping hand to help me rebuild the motor.
ill happily pay you for your services etc but my main priority is getting my car back on the road as i dont have a daily.
any help will be greatly appreciated !
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
