i can too, involves the sale of the 34 however. just couldn't part with her if i tried.
id be able to keep the 14, and be mostly if not all debt free. its very tempting.
ill probably put a couple grand straight onto the loan, and just enjoy the rest.
and by enjoy i mean, new seat, coils, good rubber, dump pipe, front pipe, cooler, ebc, retune, and track day.
Edited by scandyflick
im confused mitch? wernt you saying that ur motor was dead and needed a basic rebuild?
no ,i never said it was dead , turns out the battery in the car didnt have enough power to turn the motor over .
started it up yesterday , was a loud noise , disconnected power steering pump and there was a small knocking noise in cylinder 6
car idles fine and revs up fine , just could do with some minor work .
i beg to differ how does a spun bearing now become just a slight knock in #6
As you might know , my rb26 has spun a bearing.
i have replacement parts to fix it but my only problem is getting the engine out of the car and doing it myself.
seeing as im really low on cash i was wondering if anyone could lend a helping hand to help me rebuild the motor.
ill happily pay you for your services etc but my main priority is getting my car back on the road as i dont have a daily.
any help will be greatly appreciated !
