Here is the details, any one care to translate to english for me?
ACCOUNT DETAILS
Calling Line Identity Status as at bill issue date:
Your number is displayed to others unless 1831 prefix dialled
Payments
Details Date Amount
Payment received - Thank you 21 Mar 49.98CR
$49.98CR
USAGE CHARGES
Service Charges
Details From To Amount
Monthly 'yes' Everyday 5GB Access Advance27 Mar 09 26 Apr 09 45.44
Short Messaging Charges
OPTUS SMS/Group/Email SMS 3.63
Billed Messages 16 units @ 0.227
'yes' Everyday 1,820.27
$1,869.34
Plan Options/Bonuses
Details Amount
yes Everyday Incl. Value Credit 911.18CR
$911.18CR
TOTAL USAGE CHARGES $958.16
'yes' Everyday - Tiered Charges
Tier Price ($/MB) Volume Amount
0 - 7340.0 MB .0099 7340.032 72.666
over 7340.032 MB .1331 13129.970 1,747.599
Total Volume: 20470.002 MB $1,820.27
4.50 - 000237 - 021139
à
how the f**k did i downlaod 20 gig? i think its wrong....
did you leave your peer to peer software running? optus and telstra both charge uploads as part of their 'acceptible usage policy' (usually= download limit but since they charge for uploads too, you might very well be screwed here)
-D
na, i only leave limewire on while im on the comp, never leave it going, specially if im not downlaoding....
just see what they say,, we will play fair for as long as they do...
commence being on hold
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnow.
if you were using demonoid youd be using something like bitlord to download the torrents, if you were downloading high demand movies, your upload rate wouldve been just as high if not higher than you download speed.
dude i feel for ya and all.... but how did you go 15gb OVER your limit and not know it??
Hope you can sort that out, who has a grand to throw away!!
must be all that german porno he downloaded
"Essen mein sheisse!"
-D
yeah, I'd imagine the streets of Adelaide will be considerably quiet over the next few weeks due to recent events..... I'm sure it'll pass though.
Late reply:
It's easy to say it'll die down, which it probably will. But as soon as it does decide to die off you can guarantee that someone else will f**k it up for everyone or it'll be x-mas holidays. Sad really, I've been thinking really hard about selling up because I cannot be bothered with all the bullshit that will be going on from now on.. I don't even see the point in getting the car off defect for the time being.
Late reply:
I don't think there is an issue. I believe that the police at least have not tarred us all with the same brush and know that the street racers are in a minority.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
