this is your typical SAU wasteland reply to a serious news issue:
The Hells Angels had ice cream. The comancheros got the shits because they didnt. The Banditos were heaps pissed because no one had told them about ice cream to start with.
Some one had a gun, some claret was spilt and no one got any f**king ice cream.
Simple really.
bahahahaha :sick:
Pete, I've noticed you've been using the word "OT" to mean both On-Topic... AND... Off-Topic in various sentences. Reading along and then come up to "OT" and need to pause for a sec to see if in that certain sentence it means On-Topic or Off-Topic. :D
haha, sorry Vu, in my case it definitely meant working over-time but yeah I'm just being lazy as I always thought it referred to being On Topic........will have to type more next time.
That last one was a crack up Damo :D
I have an amusing pic a friend took of me during a crash at Mallala. There is nothing more funny than a crashed rider not in control of the camera moment :)
Mick Doohan's advice on what to do when in a crash on the track: "Just go all floppy!" :D
Here is one not quite work safe ... but funny anyway.
http://img.photobucket.com/albums/v129/Reu...cs/image007.jpg
Edited by RubyRS4
How about an SAU meet at the Tap Inn one night ... then head upstairs to the driving range.
Always good for a laugh. :D
That's not really golf, hitting balls in an indoor range. I think you have to hit balls first because the last time I was there they didn't let us after a few drinks..... We were intoxicated somewhat I though!
I went there for a mate's birthday. We weren't smashed, but we were far from sober, and had no probs.
Besides, smashing golf balls like Happy Gilmore is all I can do :D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
