lol Luke.....just need a big sock over the T51 and should get thru Regency as is :laugh: .................................NOT
Evos are unbelievably fast when you see them in action. A mate has an Evo6, have cruised with him and done hills drives with him, unbelievable.
And the sound that thing makes at high RPM is phenomenal, never heard anything like it, it was.... like a bark more than anything.
Phenomenal cars, love em. If you see them driving flat out you will appreciate...
Problem is they are worth much more than 33's so a trade up is not on the cards, not as long as we keep throuwing money into that sexy R33-shaped pit.
.................... go the money pits.
Beauty about Evos is the standard ECU, AFM, injectors, etc... can handle so much. This guy pulled up next to me at the lights and turned his boost up to 19 PSI and took off.
Right now I'm running 13 PSI and can't run any more without spending big dollars, injectors, turbs, ECU, bla bla bla all the usualy crap but that's a lot of dosh.
he can get in a standard evo 6 (apart from exhaust) and turn it right up. I'd be interested to see what it puts out on a dyno....
got a few mates with evo's and quite frankly i wasn't impressed! maybe all of the hype about them didn't meet my expectations, it was fast shit you not but to me a rwd is still more exciting! but i guess i don't like them but respect them for being fast!
^doubt it... i'm putting down almost 200 and he was miles ahead, 4 car lengths....
was this of a stand still launch, if so they of course he will be in front and given a long enough rd you would reel him in
steve's onto a point
evo's, rexes and the like are quick off the line, but are limited to top end gearing (considering their heritage is for fanging sideways on gravel at 140+kmh)
mid sized cars (skyline, supra etc) are relatively quick off the line, but still have a better top end than the smaller 4wd turbo cars
then ya big 8s are good for top speed, but not really for take off with extremely low gearing
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
