thinking about changing to one of these
wait till you throw a balance shaft on the 4g63, mine did off idle , a very common problem, destroyed the block in seconds. and the all wheel drive fuel economy sucks.
mitsu dependability :cool:
turbo failure a few months later, and a few clutches, gearboxes, and transfer cases later.. good thing it was only a daily not a racer, or it would have never made it to the race track...daily driver, hell it was broken down more then it worked..lol
and that was on a basically stock tune evo/vr4 drive train, not a highly tuned monster.
plus R34 prices have fallen into the toilet for resale ?
go for the Lada..lol they come with duct tape and bailing wire to make them last forever..lol
I drove Munro's Evo 8 when it was brand spanking new and it really didn't inspire me .... and looked like a chick's car .... yawn
At the end of the day it is STILL a lancer
so i went to lonsdale to get my r32 inspected (vic -> sa) and of all the things i could possibly get picked up for...window tinting...
'too dark on the rear quarters and the whole rear window'.....silly stuff, guess im back to peeling...
mitsu dependability :(
I knew someone would piss on my parade :(
parade pissing is awesome.
a 19mm nut on my front left strut pissed on mine, last person to work on the suspension partially rounded it. cant fit a 19mm anything onto it. pu.
Did they let you drive it away from there? When I changed over rego at Regency on my old MX6 in 2002 they gave me a razor blade and told me to get the tint off on the spot, else get a tow.
Sounds like a light angle grind on each side then a shifter spanner or locking pliers Dave. Works a treat!
+1 have done this a few times,
also a thin file on a rounded phillips head makes for a good ghetto once off flat head fitting
anyone know when/how carsales.com updates? or anyother sites i should check out
im pretty sure tradingpost.com is every thursday but i dont know about the other sites.
i like to keep my eyes peeled for any 240z dato's for sale amunst a few other oldschools. 14k is the best ive seen for a clean 240 so far.
cops wont hate on it and i might even be able to park at shopping malls with it.
Edited by Inline 6
lol sounds like my issues dave, sinergy put my tires on and obviously used the wrong size socket on my expensive blue alloy lug nuts. had two rounded out in a big way, they went thru the trouble of filing them off after they got them off to remove the burr they left . only issue was it shows bad on blue nuts when the rest of it is shiny alloy.... trained monkeys , a socket must fit tight on the lugs or the rattle gun kills them when you hit the trigger, its not rocket science ????
Oh damo,, its always better to piss(hear about issues) before you shit(buy a piece of shit)
you could always buy a forden executurd...lol
build a RB30DET GTR driveline, VE holden.. ex cop car...lol talk about stealth
AFAIK those sites are live, so once u submit an ad it is up for the length of time that u pay for (much like ebay)
Or enclose the bottom of the VE, put a few fins on, and turn it into the boat that it is. RWKW? I think not. How many killerwasps do you have at the prop man?
For all you Galaxy, Star-loving people out there...
Earth is tiny compared to these other planets:
http://digg.com/d1ofQT
i didnt know jj.am had educational stuff? i thought it was all just naked chicks and racist gifs.
you know what that all means though? we all gotta start compensating for size of our planet.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
