pascal clinkers ftmfw!
bought a digi cam yesterday, some samsung thing...
pretty good for what we need it for, only paid 340 for it so cant complain!
gotta go to jb's and buy another SD card tho, are they pricey?
SD cards are fair cheap... but depends how large of an SD card you need - taking photos 4GB or less is sufficient and cost stuff all... filming in HD 720P/1080P you'll need much larger capacities which jumps up in price alot.
Who knows how much this laptop is worth? >>> CLICK HERE <<<
Selling it for my girlfriend who has destroyed it but not sure how much we should be getting for it... had people sending offers of like $200 and $250...
^^ whats that hooked up to the PC :P
haha no i have a logitech x5300 for the PC...
the fender telecaster is connected to the marshall jmp1 preamp which is connected to the fender amp... and I got an electro harmonix big muff pi on the effects loop ;)
Was playing Dick Dale's Miserlou (The Pulp Fiction theme music for those who dont know the name) and it sounds sweet with the spring reverb
Gnarly
-D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
