i hear what your saying Son dont worry.
but these guys know what they are talking about, and they know what the limits are of the drivetrain etc when it comes to it no matter what kind of car it is.......
for example CAPA have a black ss ute that i think has the 800hp blower on it and that is running a fully stock transmission!! and they havent had an issues at all even with 30+ dyno runs.
it comes down to what i want to do. if i decide i am gonna keep her as show and dyno queen (which im happy to do) ill be fine....
ehm, the 'fully stock bro' transmission in any recent(ish) ss is a tremec t56, basically its a tank of a gearbox, capable of handling stupendous torque loads, everything is oversized and beefed up in a t56, takes a left arm made of iron to shift though. they make rb25 transmissions look like theyre made of glass. why do you think big power drag skylines run after market gearsets or even built autos and hollingers? because the stock gear set will shit the bed when it tries (in vain) to introduce nigh on 700hp to the pavement through a set of grippy tyres...
and youve gotta remember, the load on a cars driveline on a dyno is pretty minimal, and strain is built gradually, start in second gear, slip into 4th at 60km/h, then into WOT. very easy on a driveline compared to slipping the clutch at 4000rpm on slicks.
the 5spd R34 box wont handle the power, the torque will strip off the gears quick smart or brake a shaft. dynos maybe ok, but one drag launch kiss it good bye if you have traction ? if it doesnt break the half shaft will or drive shaft...drag racing kills parts, its a $$$$ option to drag a skyline with audio gear in it
aluminum flywheels kill your low end grunt feel, I had one for 11 years. good for track days, good punch out of corners , lousy for street duty or stoplights on hills..lol add a 3 plate clutch makes it worse,, on or off only?
chro molly is a better choice .
Im not a holden freak but Im semi sure they run a Getrag 6 spd box, same as a supra TT and vette.. much much better box then the 5spd, way stronger
close, see above, tremec t56, used in dodge vipers, z06's, ss commodores, and im reasonably sure turbo falcons use them also. big heavy f**kin boxes, but nigh on unbreakable.
Edited by scandyflick
in the latest HPI theres an article on an R33 gtr, and i quote "with a figure of 530hp at the fours, second gear and an input shaft from an OS-Giken cross-set were smashed to pieces"
Does it say how long he was running it though? depending on who ya know and what you can do yourself sometimes its better to just replace the standard item than go all out. i know people that run turbo swifts with the special 4wd jap version box at a cost of 7k a box while some just run the standard box and replace it every 2 years when it blows from the extra power.
also you might wanna think about the amount of cash thats getting thrown up on ideas to spend, you could say do a round would tour while ya still young enough to enjoy it :P or alternatively invest it and look to retire early. or dump it on a drag car that will break parts no matter what you mod it with. at the end of the day something gonna snap sooner or later.
Edited by Inline 6
yeah, its pretty average, and im rather disappointed. the front pipe (from the same mob) is pretty good by the looks of it, the dump pipe however, as you can see, is pretty f**kin horrid.
Man thats pretty ugly Dave.
Good to see grey imports off the msn site, replaced by locally available http://news.ninemsn.com.au/national/803971...speed-car-crash
Got a mtric tap and die set here if you want to try clean the threads out a bit Dave.
Edited by Jamesrb25
