So..... I kind of went and put a deposit on a new daily tonight. Pretty over driving the Hilux around, wanted something a little more luxury. This is what a got, should have it in my hands next week.
:P
Congrats on the purchase. She's a beauty.
I've given up trying to sell my black RS4. Been months, mine's 2K cheaper with half the kms on the clock ... but can't find a decent buyer not trying to scalp me. Now also considering parting the silver RS4. Just tired of the headache.
What plans you got for it? Apart from cruising with the best breed. :wub:
What plans you got for it? Apart from cruising with the best breed. :P
is yours the 1 that was at christies show with the kit on it?
Im gonna try and leave it pretty much how it is, only thing i wanna do is put a towbar on it and maybe a front lip, if i can find a good one. Its an awsome car in mint condition and thats the way i wanna keep it.
Ruby, bring that dump pipe of mine with ya Friday if your coming out, i have a car to put it on now. Also do you know if R33 or R34 front pipes fit stags?
They should fit. To my knowledge its from the cat back that is different.
I'll bring out the dump this friday then :P Take a peek at the new toy too.
I wont have the stag for this weekend, but hopefully have it for next weekend
Sweet ride there Chad, will look good with the 32 in tow
Not sure if i can tow the skyline with it, i'll have to do a bit of research on what sort of towbar will fit on it. Theres a Stag in the 4 sale section that tows a EVO so hopefully it should be able to tow the heavy ass skyline at some stage.
series 1= r33 rb25det, i think, and series 2 is rb25 neo?
yes R33 S1 complete exhaust fits on a S2 stagea without too much drama Roo bought my old exhaust and everlast fitted it easy enough
good one chat, sooo holding back from saying Oh another volvo driver :wub::)
nice cara should be a reliable ride there not we all have dailies who are we going to spot
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
