huh.....I thought it was for her 34?!
Your bro must have other issues Carl (condensation in the fluid can have a similar effect sometimes).....Red Stuff has a very low coefficiency which makes them quite effective when cold, mine would throw you thru the windscreen 1st thing in the morning on the way to the shops.
EBC Pads
interesting to see that the effective temp vs braking force at the low end is pretty consitant through the lower end of the range.
looking at that chart, something must have gone wrong with the brake set up, as he used to have yellow stuff on the car, and it was much more streetable than it was with the red.
the brake booster has since been replaced on the pug, i have not had a chance to drive it since then, as its now a hill climb car that lives in a shed.
yeah that does seem somewhat strange Carl.....especially with his experiences with the Yellow Stuff.
Guys like Chad (Dstroy), Andrew (Blue32) and eventually Luke (ENR34), who regularly track their cars, could do alot worse by not at least trying the Yellow Stuff.
For track only, the Blue Stuff freaks me out a bit cause I'm guessing that not only would they squeal like a pig on heat but they would be very hungry on the rotors.......hence why the Yellow Stuff would be a good option......cheaper and quicker to replace pads than rotors.
can i give your car some finishing touches with a shotgun cara?
guaranteed 1st prize !
yeah no dramas carl.....just make sure the design looks half decent ok!
6 or 8 pot?
depends what i can find at the time......maybe just have to go with r33 gtr 4 pot....but considering the car isnt going to be drivin stupidly hard they should be all good for what im gonna be usign her for
they are for the 34 :)
i quite liked the sig!
tis a bit large tho. in consideration, sig scrapped...
BOLOGNESE :)
i see its back again :)
its been reported
a signature by definition isn't a movie its a picture that the community can quickly see who has posted, 1403.43 KB (1437109 bytes) is inappropriate
you may see this as harsh.... to bad
i see its back again :P
its been reported
Maybe you better report your mate Heslo, as his is a movie also.
his isnt 1.4mb
from memory its 600kb edit not even 478.36 KB (489841 bytes) thats why i have never complained about it
yeah Carl cables extreme unlike Sydney we only get 256k upload
lol, there are perhaps some things i can do....
not sure if u are aware, but there is a flaw in the monthly quota being reset, and u actually get unshaped the day before your account anniversary date... so there is the potential to wax about 18Gig on the last day at full speed if u have good torrents or use news groups.
im pretty sure that only works if u are shaped b4hand tho
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
