all the power curves will look like this
-___________________________________________
:D
EDIT: GAY! wont post it the way i drew it :P
i fail
Edited by craig R33
with everyone gettting a new daily pos and the rolla gang. how about a dailys dyno day :P
categorys of most hp, lowest hp, best bang for buck, most fkd up power curve :D
my daily has around 175 at the wheels.....id prolly win the worst fuel map
taken from the almighty facebook
there is no DA (drift australia) this year, but there will be a one round drift nationals in SA Mallala, the home of drifting!
there will be lots more things
~ U-pull it thrash for cash burnout comp (sat)
~ Street pro-class
~ DR stunts, extreme bikes
~ time attack
DRIFT RIDES - 3 laps $150 (see mallala website of details)
the RATES are
SATURDAY - $25
SUNDAY - $35
WEEKEND - $50
gates open 11am sat & 9am sun
u dont wanna miss this
http://www.mallala.com/
wonder who takes you for a thrash for the $150?
Shannons insurance fail. My premium is $1850 a yr :) Just got the letter.
Even if i get a daily it will drop only 5-10% and the daily car has to be in my name :( So even tho i drive the work ute that doesnt mean shit. Grr
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
