haha your all good mate ,
the engine isnt going to be started for a while yet , still need turbo/manifold , coilpack loom afaik
haha i hydro locked mine when i changed my injectors... was a funny sight watching the fuel shoot out the top when we undid the spark plugs!!
Have you thought of anti freeze type stuff in a pressure pack
Forget what is called really cold but
http://loctitefreezeandrelease.com/ thats what i was talking about
I (L) Government connections.
not usable bandwidth though :)
Amazing. Looks like we're going to have a stupendously large deficit for the next 8 years thanks to Rudd n co.
Global Financial Crisis is one thing, but this is just stupid - unless the defence expansion is counted as part of that long term deficit (who knows till the budget comes out)..
Still, with 70billion in deficit, it looks like Ruddy's gonna be a one term PM.
Sux2Bus.
-D
Edit - Whoops. One too many zeros there. Heh.
Thankyou Ben :D
can someone link me or give me the jist of how a permit works? im lookin into a track car without the need (preferably of a trailer)
say i have a car that is not registered, not defected but i want to get to a hill climb/track day etc etc is it hard?? or only hard for those on defect?
then how does this effect your insurance as the car is not registered?
i need new rear brake lines :) the stupid things have been rubbing up against my rims :D can i get ADR approved rear braided brake lines at all?
Yes you can. I got ADR approved ones from a group buy on here through brake west in Syd. Maybe give them a call and see if they still do them.
killa ill look into them. do you know how much they were at all?
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
