I hate facebook quizes. Any way to permanently block them all from popping up?
I get sooooo much rubbish on facebook ... makes wasteland look organised :happy:
Cara ... I'm coming down for pie! ;)
does anyone know how the hell to get the mirror controller out of the dash surround ?
ive been here for 20 minutes trying to figure it out hahaha
Pretty much gotta take the whole dash facia off, unless you can get it out far enough and not crack it. You have to press down on the lock tab pretty bloody hard.
yeah i know that much , ive got the facia sitting on my desk, got the air vents off it and all the buttons and clock , just not this power mirror module :happy:
So who here knows how to finish a 100k service? Got all the belts off and need a balancer pulley to remove the timing belt. If someone wants to lend a hand tomorrow after work that would be great.
Them sigs how it says "join now"... shouldnt you have the sig clickable and linked to a thread where they can read up the details on how to join so is actually able to join? Its false advertisement "join now"... they cant "join now" because theres no details. I'ma sue yo ass. :happy:
big thanks to luke (heslo) for giving me a hand with my turbo today. took a fair bit of tweaking, but the nuts are off, water feed is off, and the turbo itself will be coming off tomorrow. and ill have an AM dump and front and my hi flow cat hooked up by tomorrow week. awesome.
Scandy, surely jj.am/4gifs or whatever they wish to be called nowadays, wouldnt copyright their published photos? thinkin of stealin some for SAU:SA sigs.
dunno, cant find any copyright information, and it does say 'Images uploaded are the responsibility of the Poster.', so basically, i dont think they'll care. go for gold son.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
