im getting one too. :P
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
I thought you got the GK dump, or did you end up sending it back?
I have access to a fair amount of the adhesive reflective heat shield material that I figure I can stick to anything that might be affected if need be. I can't see myself upping the boost or driving it hard enough to warrant heat wrap.... but if there's something I might have overlooked...
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
Suppose it depends whether you're running a pod or an enclosed CAI. If the later, probably no real need but if you're running a pod, may make a difference in summer by removing some of the under bonnet heat.
Again, a wise choice :P Considering getting a whole system?
No. I have an Apexi N1 Evolution cat back I bought from an interstate forum member in December last year collecting dust in the garage, I'll get this fitted when I get the dump/front and cat fitted.
No pod SLED, factory intake with apexi panel filter.
still got that pos... sold the front pipe, still selling the dump pipe. couldnt be arsed arguing for a refund, so im just selling the shit. luke called andrew the other day while he was helping me with my turbo and i decided id bite the bullet and buy an AM dump and front.
ns? :laughing-smiley-014:
nothing like a real cornish pasty Stevie
depends on what u call real
the cornish pasties they sell arent quite authentic, being that theyre just meat and vege mix in a shortcrust
a true cornish pie (as was made for the miners) would be comprised of a meat section and a fruit section (representing the main course and the desert respectively) and the end would be a big knurled section of pastry that would be thrown away (since the miners hands would be covered in coal soot)
you might have the forward section made of beef and peas or something like sausage and potato, and the second section would be diced apricots or plum pie... usual cornish fare, but baked into an all-in-one snack
trivia 101. you may leave cash donations on my door.
-D
into these cornish-pasty.jpg now are we :P
Thats a samosa dude.
I have a rad samosa recipe, with ground beef, tumeric, cumin, garam masala, salt n pepper, garlic and a pastry made from wheat and butter, deep fried to orgasmic perfection
whoever ur wife is, she wishes she had a dohmar right about now
-D
-D
for the record,
i aint making u no frikin cornish pasty,
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
