hmmmm Garrett T51R with 6 boost manifold
*squels like a little girl*
me likies ;)
youve conformed?
youre less cool than you were when you were supercharging it.
:P
Edited by scandyflick
whats everyone up to today?
Work ... and lots of it. :P
Both my admin assistants are off today, so I'm in the office alone.
yeah keep me in mind in 5yrs time if you part with it.
always wanted a v-twin, and the TLR would suit me nicely
mind you, an rsvr aprilia Mille or honda sp1/sp2 would be interesting as well
The Mille is still too pricey imo. And I've ridden an SP2 ... you won't like the cramped riding style and the frame flex under abuse. Brakes are good tho. But I've got Brembos on the TLR now which are far better.
youve conformed?
well considering i found out i was lied to about the rear wheel power figures with the 850hp blower, the other two options were to a) go to a 1200hp blower which would cost me $4500 on its on (then on top of that would need belts, etc) or b) go turbo
now as much as i dont want too :P
im seriously considering the T51R as my turbo of choice, it has also been recommended to me by Sam at Chris Milton Engines, ill be going with the 1000hp one, which also means going RB30 bottom end, (dont have a choice).
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :D kinda works out good i think lol
and :) to you to dave :P
hahaha join me for lunch?
i cant believe that i will be staying here tonight as well......and i thought Naracoote was bad enough sheesh
ahh well
there, there,
there, there krishy. youll be fine ;)
ner ner i got day off :)
now as much as i dont want too :)
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :P kinda works out good i think lol
and ;) to you to dave :P
how many people did it take to convince you that the power output you were expecting was simply too much for the supercharger you were going for?
why the hell you need 500rkw in a state that doesnt have a drag strip is still beyond me though.
wait, i forget, isnt sam the one who said *insert stupid power figure here* was achievable on that tiny little supercharger too?
bah, sad panda spec, another 2 days until i get the 200 back on the road. :D
i dont intend to drag her dave, im not building for that reason.
and sam wasnt the one who said about the power figure, the dude at capa was. he originally said i could get 500rwkw, then when i re questioned him about it, he has said 300rwkw.
look im happy to spend the money i will be spending on my engine to be built, but by hell, i will not let a engine that is capable of 500+ go to waste with something that is only gonna help me make 300rwkw.
who you gonna perve on all day now :P
its month end here and i got uni assingments to do ;)
and i think cara just likes to stir people with these posts of options, next plan v8 in the 34.....its been done cara
Edited by Inline 6
id put a v8 in the s14.
wide body, potato potato LSx, fat meisters, and the ability to stab the clutch in any gear and turn the rear tyres into smoke. awesome.
should mention that heslo disagrees with this idea rather strongly. :P
is it worth dropping 30k on an engine for it to get some numbers on a screen? i mean the only people that respect dyno queens power outputs are other dyno queen owners, or 12yr old boys?
**yes yes, i know horses for courses but im just tryna get my head around it
*** why not just spend that money on some crazy wide body kit, massive dish wheels and more vynil?? or do you really just want a autosalon dyno trophy?
Edited by rhys5169
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
