:closedeyes: Not a worry mate, small world eh?
Andrews stuff is indeed quality, you WON'T be disappointed! What did you get made up?
Yeah tis a small world. After watching you guys reverse up the street I just reversed into the driveway on the corner... too easy lol!
I got the split dump/front pipe and hi flow cat
on the talk of ebc, found out today my greddy is dead :S
weighing up wat to do now.
Should i get another ebc or should i just go a bleed valve?
Experiences and opinions welcome.......
hmmm may have to go visit a friend at autobahn then tomorrow if they are that cheap now, think i paid at least double for mine a couple of years ago.
yeah, hdi's are going $180 - $350. cant be that bad, use the same gear as the higher priced stuff on the market.
LOL, no one has noticed yet........would've thought the post whores would be more alert. :closedeyes:
Who will work out what I'm talking about 1st?
and MODS, shhhhhh!!
stop being cryptic god dammit. its 0030.
