wouldnt of thought NA RB would have enough power to utilise the RON
i didnt wanna say it.
LOL that's what i would have thought?
What static compression do they run?
9:1 afaik.
just for comparison, my old toyota ran a cr of 10.5:1 and didnt have any problems on any premium fuel. cant see how the lower compression nissan engine would suffer problems.
my car lost power with the v-power fuel, she hated it ran like crap and detonated off her nut :laugh:
I'd be taking her to the mechanic in that case, could be many other things like spark, coil packs, afm ect ect....
Mine runs just fine on V Power, I wouldn't say it runs better (than Ultimate 98) but I definitely get better fuel consumption on V Power. But I'll use either, depends where and when I fill up... :nyaanyaa:
Well the issue is resolved. Found some octane booster in my shed, put it in this morning and she runs fine now. f**king shit fuel. :nyaanyaa:
Edit: I should add, it doesn't matter if the engine is forced or na, shit fuel is still shit fuel. Don't you think NA cars suffer detonation too?
I've got a new name for V Power: Vagina Power = its a c*nt of a fuel :laugh:
Edited by RubyRS4
almost there. intakes been hooked up, disconnected the cas and cranked it a few times, cant see any leaks, but ill have to wait til i actually start it to know for sure.
just waiting on a couple shorter exhaust studs, and then its start time. getting anxious now. lol.
What servo did you get the V-Power from Ruby? Was it a servo that is very busy? 98 ron fuel (no matter who makes it) will lose octane as it sits. So if it had sat in their tanks for 3-4 weeks because no one had bought it, then it would probably have been down around 95 RON.
The trick is ALWAYS buy your fuel (BP, Shell, Mobil) from a very busy servo. Tanks get drained quick, which always means nice fresh 98 ron fuel.
The same applies if you put you dont drive your car for a while. If it sits for a month or two, ALWAYS add fresh fuel, or at least octane booster before heading off again :nyaanyaa:
Supporting the above, I've use both V-Power and BP Ultimate in all my cars, and each fuel is the same as each other - never a bad batch because I always visit busy servo's on main roads :laugh:
I think I just encountered a bad batch. Still wasn't happy about it.
I always (99.9%) buy my fuel from BP near Greyhounds and BP West Tce, or Shell West Tce
Not sure if I should name the servo ... but its located near the brewery :nyaanyaa:
Edited by RubyRS4
See now that is a pretty shitty small servo - it wouldn't surprise me if the don't sell much 98 there at all and you got some old horrible fuel.
(probably sell plenty of 91 with the 4c dockets for all the dero's heading home to the western suburbs :nyaanyaa:)
Just a quick question...how do i get the static compression ratio of my car???? std rb30 but with a set of hypatec dished pistons??
a compression tester ? if its a built engine, or you can calculate compression based upon measurements,bore,cc of cyl head etc if the motor isnt built yet
how awesome is having 3,333 posts?
not because im a post whore and wanna brag about my fairly large e-penis, i just like having numbers line up.
that and a dollar coin will get you a few min at the car wash to wash your penis dave...the one that counts is the "666" post :nyaanyaa: ...lol
(probably sell plenty of 91 with the 4c dockets for all the dero's heading home to the western suburbs :P )
Aww c'mon ... its right next door to the fully hectik Super Cheap yo! Thats gotta be worth a few extra kw. :nyaanyaa:
Had no choice, right near empty and I failed to stop at BP West Tce. :laugh:
the devil is my bitch.
srsly.
ive got a photo around here somewhere...
... anyways, got a price on those work meshies i posted some pages back. bout 1400 beans. be able to sell my enkeis to make up at least half that i reckon.
:EDIT:
for anyone that cares, these are the wheels in question;
went out side with a couple rulers, fronts will sit pretty flush with the camber im running at the moment, rears will sit *just* proud with a 5mm slip on, will require some rolling though, and a bit of a lip when i get the camber sorted. jawesome.
Edited by scandyflick
meshies look awesome, def one of my favourite style of rim to suit a skyline or a 2hunj
love VS-XX work or the Weds Kranze mesh - or BBS if youve got the extra coin you dont mind parting with your left testicle, first born son, and soul.
Ebay find:
A bit too "out there" for my liking. It'd be a cop magnet in Adelaide
http://www.cgi.ebay.com.au/R33-Nissan-Skyline
and here's a fail:
http://www.cgi.ebay.com.au/1999-Nissan-Sky...R34-GT-R-Purple
:dry:
Edited by RubyRS4
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
