anyone know where to get that uber cool coloured mesh from? ive tried profix and midas, but they say its only show car material; needs to be exclusively ordered from hyundai..?
Edited by steveP
Hey - why is there so much beef between SAU and NS anyway?
I heard it was because most of you think that NS gets bad rep with the cops, but it was SAU that tried to befriend cops and then got defected, right? Yet us ns.com peeps don't have that problem at all... so that must not be the problem.
so...what is the problem ?
I'm gonna step in here and try and nip things in the bud cause I can see this getting out of hand.
Be warned that not only will your posts get deleted immediately but you face a possible life time ban from SAU if everyone from ns.com comes on here for some retribution towards Ruby or other members.
Ruby, SteveP, 5LTBETR & Deluxe, consider this a friendly early warning.
EDIT: SteveP, the couple of times I've seen you out, you're as quiet as a mouse, but so heroic in here.
I dont think its so much of a beef, its like two brothers living in the same room, or SA and VIC.
I dont have an issue with NS, having previously been a member when i owned my S13, maybe someone with the hate inside their soul can shed some light?
I also wonder this. Everytime I visit the SA section here I always read atleast one or 2 stabs at NS, yet when I read NS (alot more then SAU) I rarely even see a mention of SAU. :dry:
hrmm oh well back to classic skylines.
Yeh i dont understand either Bill, it all happened between a few people in the All Japen Day thread over on the corner of NS.com, and then today it has happened again, but seems to be with the same SAU member.
I used to frequent here alot more before, but things have changed, and now see myself at NS more than here now, I used to be a "Yeh NS is so childish" sorta person, but wow how things can turn!!
Thanks Pete for the early warning!!
i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
... just sayin.
correct
Hello :D
Just wanted to say that I have not bagged RUBY at all... yet.
Just also would like to add that he asks for it with his behavior.
I would just like to say that I did
and will continue to do so
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :dry:
how many e-creds does that take your tally to now?
how many more before you win the giant panda bear?
Well the issue is resolved. Found some octane booster in my shed, put it in this morning and she runs fine now. f**king shit fuel. :dry:
Edit: I should add, it doesn't matter if the engine is forced or na, shit fuel is still shit fuel. Don't you think NA cars suffer detonation too?
I've got a new name for V Power: Vagina Power = its a c*nt of a fuel :D
Just looking through ebay and found this, VP commodore styles much!
*looks a rear wheel arches* .... *Runs to vomit*
:P:sick:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
