thats pretty deep. ted knows alot of bikers, some with motors in their bikes aswell
didnt know you were banned ted. so they got you on a warning? 20% 50%? ah who cares important thing is your back to provide fun and friendship as always.
Edited by Inline 6
When comparing girlfriends and cars it should not just be about $ - otherwise we should be comparing hookers and cars. There is also the smile per mile and the cringe per winge measurements to be included.
Everytime something goes wrong with your car - ie a winge - how much does this cost in $, deprivation of smiles and emotional damage? Everytime your girlfriend is unhappy and lets you know it what is the total cost in $, deprivation of smiles and emotional damage?
Whenever your car is running perfectly and just purring along how happy does this make you feel? Likewise whenever your girlfriend is happy how much of this gets passed on to you and plant a smile on your face?
I haven't worked out the formula yet but I will get back to you after consultation with a mathematician, a mechanic, a sex therapist, a psychologist, my GTR and my ex. It already sounds like a complicated formula.
Edited by writeoff
bikers wear spandex.
riders wear jeans.
which one is ruby?
You forgot kevlar. I wear kevlar reinforced Draggin Jeans (minimum) :)
that a trick question ? i dont play with bikes, i dont know wtf your talking about. so you wear spandex?
Push bikers wear shorts/spandex
Motorcyclists (bikers) wear leather/denim
'Squids' (wannabe bikers) wear shorts/tshirts
Scooter riders (refer 'Squids' above)
Bikies wear whatever the f**k they want ... you got a problem with that? :)
Dude, I have the answer: we're all f**ked.
gf's vs cars..
u spend money on a car, u get what u pay for.
u spend money on a chick, its all up in the air if she decides to put out.
its like filling up ur car at the petty station, then after returning from paying, the empty light is on.
end discussion!
Edited by steveP
jealous cos i can make purple look good?
dont flatter yourself post-31501-1242966804.jpg grimace made it cool way before you ever wore it
and what you doing on a skate park, don't look like your skating. take it on the dirt
Edited by Inline 6
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
