yeah, im starting to get pretty disheartened about it all really. :)
as of today is been 4 weeks since its moved (and has cost me over $400 in loan payments and insurance for the privilege, and the parts on top of that). im about 3 seconds away from taking to it with 10 litres of petrol and a match.
ive called andrew and left a message, im having trouble seeing how 3 components designed to fit an s14 dont work together. its doing my head in.
i shouldve just used the gktech gear. wouldve been back on the road over a week ago if i had.
Edited by scandyflick
Push it in, make it fit. push the catback out as hard as you can?
tried that. even with the catback pulled back as far as it'll go (with ZERO play left in the hangers) the gap is still about 5mm too small fit the bastard in. add another couple mm for gaskets and yeah, shit just aint gonna fit.
PLEASE dont take it to AAA Andrew is @ supercup today and will be more than happy to help sort your shit out
BUT sounds like the apexi is whats giving you grief, how is the factory cat 30mm too long :blink: i would of though the factory cat should be the right length
yeah, i left a message on his phone. figured he'd be at dsc. both cats are the same size (factory is a couple mm larger than the xforce one), both fit fine with factory dump and front, neither fit with the AM pipe fitted, the gap between the rear flange on the front pipe and the front flange on the apexi is 30mm too short, which makes me think the front pipe is 30mm too long.
ah well yeah wait till he can sort you out becuase you've paid for his work and now he wont rest until its sorted but if you take it somewhere else and they butcher it then you need to take it back how bad will that be
yeah, i just feel like a bit of an asshole taking it back, ive already had to take it back once eh...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
