mainframe computer in head office will only let us see a few different things...i can go on carpoint.com.au ...but not carsales.com.au...
http://www.bypassthat.com/ :banana:
HAPPY BIRTHDAY DOHMAR
sex: http://www.skylinesaustralia.com/forums/R3...an-t270578.html
my missus wants to give beyonce a good going over
im not sure whether to be happy for you or worried.
ok so Nat Bass isn't the best out there, but would you kick this out of bed:
i wouldnt :banana:
Yep, what Vu said.
Note that bigger injectors and cams will not help the stock turbo necessarily make more power, as at over 200rwkw it is well out of its efficiency range. Also note that unless you are lucky, a stock turbo will not last massively long at 12psi. If I were were you I would skip the stocker, as a HKS 25/30 like mine can be had for around $1,500, and the Garrett version even cheaper (makes slightly less power though).
Also, yes you would need bigger cams and injectors (my injectors run at up to 96% making 230rwkw) to make 300rwkw unless you went for a stupidly big (read = laggy and unstreetable) turbo. Not sure how long your top end would last with 300rwkw, but seems to be a fair few people doing it around Aus.
i got 186kw when willal got there mainline dyno and i had 3" turbo back exhaust, fmic, power fc, fuel pump and boost was 13.8 psi so go figure! same as my mechanics r34 gtt he got 191kw!
with a few mods i am making 211rwkw on 12psi but ur right Son as my stock turbo is running out off puff towards the redline......but really happy down low which is very good streetable power.....but just dont know how long that the stock turbo will last....it has been running 12 psi for about 1 year now and still going strong so looking ok atm.....and my dyno figures are from Graham West Dyno's
i wouldnt :banana:
I would. I hate it when people have a wonky eye, esp on chicks. Makes me wanna slap em and say "WTF are u looking at?"
Oh and I think shes got less talent than a 3 kilogram bag of horse shit. At least the horse shit can fertilize the garden, all she does is rip of lyrics from other musicians and spends half of her songs talking because she can't sing for shit....
Yeah I'm mean, so what...
-D
How much power are you looking for Cara? 300?
just wanting to know what the max would be for stock engine before i would have to do internals, the 500rwkw will be a while before that happens, and cause my car isnt a daily anymore, i guess 250-300 would be a nice "starting point" even tho i would start off stock and go from there....i know it prob sounds weird but i would rather learn from having a stock engine and going from there really.
i mean is it worth getting this ebc thing? and what the hell is a bleed valve lol
lol Cara. EBC = Electronic Boost Controller, recommended for the power your aiming at making, forget a bleed valve for your goals. Greddy Profec B Spec II is popular and not that expensive.
If you plan to go big, do it in one go, dont buy and test turbo's etc, will be too costly. Research examples of det Neo's makign the sort of power your looking at. Why not buy a RB25/30 from R.I.P.S?
Taken from http://www.ripsltd.com/products.html:
"RB30 Stock internal long engines start at NZD$5250 with RB25 head. (suit up to 600hp and 7200 rpm)"
Happy B'day Dohmar :banana:
i find her voice extremely annoying at the moment,.
and yes happy birthday ben!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :laugh::laugh:
i wish i could damo, but the engine alone is gonna cost nearly $13,000 to do.............and im a long way off from getting that sort of money atm.
the thing is, i could get to 300rwkw and be happy with that. its hard to say until im there. just one of those things really i wont know until im there, dont get me wrong, id still love to get to 500rwkw, but at the moment its gonna be a while before that happens :D
Edited by MissR34
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
