My eye wont stop twitching!! AAHHHHH
Its really giving me the shits and I felt the need to share.
You winking at me? :)
Hahaha it would be a funny sight as Penny's boss is talking to penny and see's her eye twitching lol
your not a PA by any chance :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
