No worries. I'm not desperate for the gear oil yet but I want to do an oil (engine) change pretty soon and am still debating whether it's worth spending the extra on 300V over 8100 xcess.
repco just had that big sale on motul like a month ago, i stocked up :) not sure if they had the 300v though
Okay my head is spinning ...
I've been looking around for type M kits for an R33 4 door. Started looking at 2 door type M kits, but they seem to vary alot from simple lines to big bars and skirts and wings!
Has anyone got a pic of what a true type M kit looks like?
:D
chrono was a game on supernintendo and ps 1
http://www.levelupgamesftw.com/images/Chrono.jpg
the above statements are begging for another argument on oil :D it could be the worst sht in the world but aslong as your engine dosnt die and it charges the highest price ppl will believe its da bomb
i carry a inanimate rock in the back of my car to make it run smoother, wheres the proof you ask? well it still runs like the day i got it :cool:
although i would still recommend it :happy: cept for older cars like mine that need to go for something a touch thicker
Edited by Inline 6
How do I engine flush? Ive never done it and oils due in 1500 (5K intervals) Guessing its just a additive to pour in and wait till it drains out? Im running castrol edge sport 5w30 in the stag and seems ok. Ive seen people ranting of this Fuchs stuff in the stag section and its pretty cheap apparantly asked repco about it and they said id be going backwards...?
Should i do the oil before the dyno even though its not going be due for another week or 2?
the above statements are begging for another argument on oil :) it could be the worst sht in the world but aslong as your engine dosnt die and it charges the highest price ppl will believe its da bomb
i carry a inanimate rock in the back of my car to make it run smoother, wheres the proof you ask? well it still runs like the day i got it :D
although i would still recommend it :) cept for older cars like mine that need to go for something a touch thicker
Your theory fails in epic proportion. 1) The Rock is not inaminated - he is alive and kicking ass. 2) The Rock would make your older car run alot smoother with him pushing it out back.
Therefore, "The Rock" that you have in the back of your car is a worthless imitation junk and does nothing, you might aswell have stickers on the side of your car, a GT-Wing and re-name yourself to Vin Diesel. :cheers:
To do an engine flush you buy an additive and put it in with your current oil. Let the car idle for about 10 mins, then dump the oil while its still warm. Easy as!
If your going from synth to mineral you have to change your oil filter too. (I do it every service anyway)
If anyone is interested in trying ULX 110 then let me know, the distributor works with me so could probably get discount.....
martini racing oil ftw any day :D:cheers:
What in your NA? :) ohh I forgot your friends with roo and his blue mesh :)
haha jokes aside yeah I have had nothing to do with martini, infact ive only herd of it cos of boost worx....
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
