They are top flite clubs Steve.....top flite has been owned by calaway for a while now so they are calaway made lol
Nice 1. What shafts are in them?
oh and Dave, prob a good thing I wasn't with you you last night bud.
+1
Matty31 and anyone else that cares - Repco have 20% off nearly everything in store today.
Ok looking at getting a power fc and a new turbo (mines starting to make bearing noise) in the next month or 2. Just wondering if its better to fit both at once or one at a time. I know it means two lots of tunning, but figure i can save myself some cash on the turbo install and do it my self.
James get it done both at the same time.....its cheaper that way i reackon mate
steve that info i dont know.....but it certainly improved my game on the first go at it mate.....so happy with it
I was looking this morning at a Autometer boost gauge at Repco, thing is it doesn't have the mounting cup and they don't stock the cup..... Any mounting ideas other than having to cut a 2 1/16" hole in the dash somewhere (which isn't going to happen!)?
Got a black mounting cup here Steve if you want, $20 it yours
Cheers will keep it in mind, but after having a look around I'm kind of liking the GTR single DIN setup. That way I get rid of the ugly DIN pocket that doesn't quite fit correctly.
Only problem is Defi ($$$$) are the only aftermarket 3 gauge single DIN setups I've come across so far!!!!! Will keep looking....
Fit the Power FC yourself. It's very easy. You wont need a tune as the PFC has a base map already. Unless you have made changes to turbo or injectors. Then save for yuor turbo, injectors and THEN get it tuned.
The FC is second had, had a plug in test on thursday. Not sure of mods it was tuned for though, but at least it started! Was so tempting to say "leave it in there". Slightly high idle on start up, then rough idle, possibly tuned for bigger injectors. Think that my be the way i'll go Ryan :)
Is there a way you can reset then to the base tune?
Anyone watching channel 10 at the moment, they're showing the Isle of Man TT.
That S*#T is crazy, No regard for ones life.
omg i got dizzy watching that front camera view going through those little villages, hills and jumps at 160mph. Couldn't believe it.
yes do an initialization in the settings menu. No hassles what so ever.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
