I can highly recommend jack for solder jockey work ;D (after all Im shit at it and made him do it all)
My dick is still bigger than his tho yall
-D
Bahahaha :laugh:
If any one wants to check out VDO's range of gagues...
http://www.egauges.com/vd2_main.asp
i might be getting Saber gauges depending on the price :laugh:
i recall have a chat to you about saber, i believe i may have included the following words and terms;
cheap
crap
avoid at all costs
also, lol at the post stats for the wasteland.
Damo_R34 2354
Madaz 1914
and a quick question, if i go ahead and say, buy a 2871R, id pretty have to get a retune eh...?
Edited by scandyflick
welcome :laugh:
if your interested in entrering shows and stuff im the SAU:SA Events Coordinator :D
thanks i'll keep it in mind but i think i should spend a bit of time and money on the car first before entering it in shows.
but thats the long term goal anyway, make it showy :D
I would, yes. Fit your EBC, get a retune, profit. If you could get some bigger injectors and a larger AFM while you're at it you'll make better use of the turbo but still, will be sweet regardless
Yep GT2871R will mean injectors 740cc, Z32 AFM, and a remap at the very least (at least the remap will only cost you around $600 including the daughter board) and to get the most out of that turbo you should really get cams. Without cam your looking at around 230rwkw and with cams your looking at 250rwkw. If you don't want that power then look at a GT28RS, that'll be around 220rwkw without cams and 235-240rwkw with cams. Standard SR's will take 250rwkw without a problem depending on how you drive it and how good the tune is.
EDIT!!
I'm pretty sure the use of any harness is illegal in SA.
Edited by D_Stirls
looks like ill just be getting the t28 rebuilt then, ive got other things i need to start getting the money together for. car has to be put on the back burner sooner or later.
cant justify the nigh on $2k.
i was told years ago (by regency) a harness is legal if you have the stock belt still bolted in and functioning.then i got pulled over and fined for not wearing a seatbelt,was using a 4point momo harness...and got the old Rx-7 defected at the same time for my troubles..
who knows really???
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
