back on the hunt for a turbo. the bb i was gonna buy is apparently plain bearing...
That's been for sale since the dawn of time
longer than that i think.
clearly not phased about glenn
haha, buy ryans, 300rwkw...
:edit: wtf at the exhaust on that purple 33... :)
Edited by scandyflick
saw the exhaust on the purple one, like the modding of the bar to fit them
saw that white one, has all the gear but a bit to expensive me thinks
going to look at said auto one tomorrow morning with luke, hopefully as clean as it looks and stops raining while we are there
gtir's are great for an sr20, i think mr pickering has one for sale?
yeah, done a quick bit of reading, apparently theyre a pretty stout little bit of gear. good for 230-240 from what im reading.
he does? got a link? i know he was selling a hks gtrs some time ago...
only thing worrying me in the stall converter, not really daily friendly, hopefully someone wants a build auto box (cost him 4500....eeek)
ouch. $4500 for the auto? f**k me.
i think mr squiggle made a mess on ur face luke, we got photo proof if you would like to drag it up again :woot:
:) owned. lol
Some cock tried to steal the 33 on the weekend. :down:
A club lock and alarm kinda ruined it for them :laugh:
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :)
:) i just cant help myself ruby.......i gotta stop coming round to your house all the time hey :P
I'm not gay, the guy who feels me is
oh dear..... :)
