Using the truck to pull some fence posts (sunk in concrete) and part of my fence out tomorrow.....anyone got a decent length of heavy chain and driving past tomorrow?
Oh and Chad, I'm getting the steel for the gates tomorrow too so I'll probably try and do something this weekend now that I just found out we're not going to Melbourne for another couple of weeks.
Oh and Matty, I might try and catch up after all on Sat night.
moving on from yesterday where i've been driving around with the cat being the end of my exhaust.. i now have the custom made r32 gtst exhaust that doesn't fit!! we got everything sorted to put the bloody thing on and it wasn't long enough.. got some pics as i did want to get my car home again tonight and will be going to jms to complain in the morning.. had to do 20-30 in the 70 zones on the way home and was still scraping over every small bump :P :P bolted on at the cat and secured by coat hangers at the rear for now.. but im not driving that thing anywhere cos its dodgy as
Didn't you know it's cool to argue about stuff though???
It makes you sound way cool & smarter than everyone else, yeah..................NOT.
My Dad told me years ago that God gave us 2 ears and only 1 mouth for very good reason.........think I said that to someone on here before giving him a few weeks vacation in Siberia, lol.
Being argumentitive for arguments sake is so not cool!
Wisdom starts with silence!
I'm neither smart nor cool so I guess I should start hey... :P
Steve, bring on the crushing I say..........as long as they target the idiots that give the rest of us a bad name and risk innocent lives on the road, I'm all for it.
Can't wait to see Tom's ride get crushed.......once a serial hoon, always one!!
I don't have a problem with it either so long as the punishment is warranted.
i might be getting old, but all this hoon crap, the speed camera sign removal stuff too, im just sick of it.
pretty simple solution
1. if you're doing nothing wrong you'll be fine
2. if you're not speeding who gives a f**k where the radars are
I say every member of said notorious boganwhore club should have their cars crushed..........just need to wait for them to do skids
Dont get me wrong here, im no angel, just makes me want to turn the radio off EVERY time it comes on talkin about it
so u saying driving nice and easy to work in the morning warrants getting pulled over and defected?
i wasnt doing ne thing wrong..
ahh its all a bunch of shit.. and its not gonna change for the best!
i coped it on the chin...
woooooooo the A$ went above 80c US last night .... good time for me to be buying some car bits for my new bus from the USA :P
Dave, have you heard from work about Aug 1/2? I need to change the tickets.
Hmmmmm me be trhinking Andrew may be getting an Infinity or V35!
Oh and the 33 made 195.4 at Morpowa, not bad for just simple mods. Im happy with it.......................................for now! :P
no, i didnt say that adrian. driving like a cockhead like some of the people i see on a short drive to work deserves attention from the cops. Dont forget i was driving sensibly to work and gone pinged for my "blue" headlights........so go figure on that one. Consistency isnt there. And i wasnt doing anything wrong either, copped it on the chin too
http://news.ninemsn.com.au/national/838383...rs-tail-cut-off
if i ever found who did this, id cut there fackin dick off!!! flamin mongrels
thats just plain wrong.......i rekon they should cut the ears off the person that did this with scissors and see how they feel.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
